C2G 3m USB 2.0 USB C to USB Micro B Cable M/M - Black
£17.19
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect a USB-Micro B device to a USB Type-C port on a laptop, desktop computer, tablet, or other device
  • Connect the USB-Micro B port of a smartphone, tablet or other mobile device to a USB Type-C port
  • Backwards compatible with USB 2.0 and USB 1.1 devices
  • Length: 3m
  • Stock Status: In Stock
Product codes
This USB 2.0 USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 3 metres away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and chargin. Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
Product Description C2G 3m USB 2.0 USB Type C to USB Micro B Cable M/M - USB C Cable Black - USB-C cable - 3 m
Type USB-C cable
Features Sync and charge, colour-coded connectors, nickel plated shell
Length 3 m
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 3m USB 2.0 USB C t...
£17.19
