C2G 4.5m (15ft) USB C to HDMI Adapter Cable 4K - Black
£45.18
Delivery:
Key features
  • Connect a USB Type-C device to the HDMI port of an HDTV or projector to display video and audio
Product codes
Experience 4K ULTRA HD displays with this USB-C to HDMI Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet or other device and an HDTV, projector or other HDMI-equipped display – making it an ideal solution for the office, work space applications or home use. Supporting resolutions up to 4K @ 60Hz, which is four times the clarity of 1080p, this cable offers high quality, ULTRA HD video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient one-cable solution that eliminates the need for a separate adapter or additional cabling.
Product Description C2G 4.5m (15ft) USB C to HDMI Adapter Cable 4K - Audio / Video Adapter - Black - external video adapter - black
Device Type External video adapter
Bus Type USB-C
Max Resolution 3840 x 2160
Interfaces HDMI (male connector)
Length 4.5 m
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 4.5m (15ft) USB C...
£45.18
