C2G 4-Port USB 2.0 Aluminum Hub
Key features
  • Add 4 USB 2.0 ports to your Mac or PC; hub includes hard-mountable metal base
Product codes
The aluminum hub conveniently adds four high speed USB 2.0 ports to your desktop or laptop computer. The slim form factor saves space while the port placement and hard-mountable metal base keep the hub in place even when several USB devices are connected. The removable aluminum base can be hard-mounted to your desk. The hub easily slides from that base, and makes it convenient for travel as well.
This hub can be self-powered from the USB port, or utilize an AC power supply adapter. Downstream ports have automatic connect and speed detection plus overcurrent protection with auto recovery. Add additional hubs to daisy-chain up to 127 devices; this hub delivers high speed data transfers up to 480Mbps. Whether you are downloading or transferring spreadsheets, MP3 files, digital pictures, or video streams, the 4-port hub makes connecting several high speed USB 2.0 devices hassle-free.
Product Description C2G 4-Port USB 2.0 Aluminum Hub - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x USB 2.0
Features USB powered
Compliant Standards USB 1.1, USB 2.0
Colour Black
System Requirements Apple MacOS X or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 4-Port USB 2.0 Alu...
