C2G 4-Port USB 2.0 Laptop Hub with .45m Blue LED Indicator Cable
£10.05
Delivery:
Key features
  • Quickly add more USB 2.0 ports to your laptop or desktop PC!
  • Type: USB Hub
  • Interface: USB 2.0
  • Speed: 480Mbps
  • Ports: 4
  • Form Factor: External
Product codes
The USB 2.0 4-port laptop hub expands your USB configuration and provides three extra ports for connecting peripherals. Small, lightweight and portable, the laptop hub can be readily used anywhere you go. It's fully USB 2.0 compliant to ensure compatibility with all USB peripherals, regardless of computer manufacturer or operating system. The LED indicator on the cable shows your hub is being powered, while the flip-up plastic cover protects your ports while not in use.
Product Description C2G USB 2.0 4-port Laptop Hub - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x USB 2.0
Dimensions (WxDxH) 5.1 cm x 3.8 cm x 2.5 cm
Weight 104 g
Colour Blue
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 4-Port USB 2.0 Lap...
£10.05
