C2G 5m Pro-Audio XLR M To XLR F
£12.26
Delivery:
Key features
  • Made from twisted-pair audio cable under an aluminum foil for maximum shielding from noise
  • 22 AWG twisted-pair construction
  • Foil shield and 60% copper braid
  • Nickel plated brass connectors
Product codes
Use this XLR to XLR cable to connect unbalanced sources to balanced XLR inputs. This pro-audio cable is made from 22 AWG twisted pair audio cable under an aluminum foil shield and 60% copper braid for maximum shielding from noise. The highly flexible 7mm PVC jacket reduces the risk of the cable kinking and damaging the conductors.
Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Spring strain relief on the plug and a chuck strain relief inside the XLR reduce the effects of age on the solder joints and contacts.
Product Description C2G Pro-Audio audio cable - 5 m
Cable Audio cable
Technology Shielded foiled twisted pair (SFTP)
American Wire Gauge (AWG) 22
Length 5 m
Connector XLR3 - male
Connector (Second End) XLR3 - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 5m Pro-Audio XLR M...
£12.26
