C2G 5m USB 2.0 A Male to A Female Active Extension Cable
£15.20
Delivery:
Key features
  • Extend your USB connection 5 more metres
Product codes
This extension cable actively buffers the incoming and outgoing signals to ensure compliance with USB's 2.0 specification for electrical and timing minimums. You can connect up to 4 active extension cables end-to-end to achieve up to 19.8 metres total extension! Both low and high speed USB devices will function equally well with this extension.
Product Description C2G USB Active Extension Cable - USB extension cable - 5 m
Type USB extension cable
Features Active cable (signal regeneration)
Length 5 m
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type A - female
Compliant Standards USB / USB 2.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 5m USB 2.0 A Male...
£15.20
