C2G 5m USB 2.0 A Male to A Female Active Extension Cable
£15.04
Delivery:
Standard: 1-3 working days
Key features
  • Extend your USB connection 5 more metres
  • Length: 5m
  • Stock Status: In Stock
Product codes
This extension cable actively buffers the incoming and outgoing signals to ensure compliance with USB's 2.0 specification for electrical and timing minimums. You can connect up to 4 active extension cables end-to-end to achieve up to 19.8 metres total extension! Both low and high speed USB devices will function equally well with this extension.
Product Description C2G USB Active Extension Cable - USB extension cable - 5 m
Type USB extension cable
Features Active cable (signal regeneration)
Length 5 m
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type A - female
Compliant Standards USB / USB 2.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 5m USB 2.0 A Male...
£15.04
