C2G 5m USB 3.0 USB-A Male to USB-A Female Active Extension Cable
£31.20
46 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Extend all functions of USB 3.0 up to 5m (16ft)
  • Connect up to 4 extenders to reach lengths up to 20m (64ft)
  • Powered through USB bus power or with supplied AC adapter
  • Backwards Compatible with USB 2.0 and USB 1.1 devices
  • Plug and Play—no driver required
Product codes
Extend a USB 3.0 cable 5m from a desktop, laptop, or remote terminal to a interactive display, hard drive, or other peripheral device with this USB 3.0 active extension cable. This cable supports all USB 3.0 functionality with data transfer rates up to 5Gbps and the use of USB bus power eliminates the need for external power adapters. This simple, one connection solution allows for quick, plug-and-play installation – encouraging productivity and simplifying device connectivity.
C2G USB extension cable - 5 m
USB extension cable
Double shielded
Active cable (signal regeneration)
Length
5 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
Rated Voltage
30 V
USB / USB 2.0 / USB 3.0
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 5m USB 3.0 USB-A M...
£31.20
