C2G 7m Cat6 550 MHz Snagless Crossover Cable - Red
£7.33
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Unparalleled performance for peer-to-peer and crossover applications
  • Length: 7m
  • Colour: Red
  • Stock Status: In Stock
Product codes
Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10/100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
Product Description C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 7 m - red
Type Crossover cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Features Molded, snagless, stranded
Length 7 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 7m Cat6 550 MHz Sn...
£7.33
