C2G 91.4M VGA+3.5 Over CAT5 BOX TX (300FT)
£141.48
Delivery:
Key features
  • Extend a video and audio signal up to 100m at 1920x1200 resolution
Product codes
Extend a video and audio signal up to 100m at 1920x1200 resolution.
The VGA+3.5mm Audio over Cat5 Box Transmitter, when used in conjunction with a receiver, allows you to extend a VGA signal over two Cat5/Cat5e/Cat6 unshielded twisted pair cables up to 100m without signal degradation at 1920x1200 or 1920x1080 resolutions. This solution is compatible with any operating system and is truly plug and play with no drivers or software required. The transmitter and receiver come in either wall plate or box form factors and are interoperable allowing you to choose the form factors that are best suited for the application. In addition, this solution utilizes phantom power providing you the flexibility to power at either the transmitter or receiver end.
The EDID copy feature ensures compatibility with any monitor. Built-In power surge protection and high ground loop immunity ensure high performance signal extension.
Product Description C2G TruLink VGA+3.5 over Cat5 Box Transmitter - video/audio extender
Device Type Video/audio extender
Form Factor External
Max Transfer Distance 100 m
Weight 398 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 91.4M VGA+3.5 Over...
£141.48
