C2G AA1419048-E6 SFP mini-GBIC Transceiver
£39.63
Delivery:
Key features
  • Functionally identical to Avaya/Nortel AA1419048-E6
Product codes
This Avaya/Nortel AA1419048-E6 compatible SFP transceiver provides 1000Base-SX throughput up to 550m over multi-mode fibre (MMF) at a wavelength of 850nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Avaya/Nortel transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Avaya/Nortel, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
Product Description C2G Avaya/Nortel AA1419048-E6 Compatible 1000BASE-SX MMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 1000Base-SX
Data Transfer Rate 1 Gbps
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
OEM Manufacturer Equivalent Part Number Avaya/Nortel AA1419048-E6
Dimensions (WxDxH) 1.27 cm x 5.59 cm x 0.76 cm
Weight 30 g
Designed For Avaya Ethernet Routing Switch 8683XLR, 8683XZR; Secure Router 4134; Nortel Ethernet Routing Switch 8630GBR, 8683POSM; Metro Ethernet Services Unit 1850, 1850-12G-DC, 1850-12GE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G AA1419048-E6 SFP m...
£39.63
