C2G Audio Isolation Transformer
£43.35
Delivery:
Key features
  • Stop speaker hum due to the effects of ground loops; an easy connection via standard audio cables
Product codes
Ground loop isolation transformers from C2G connect easily into your A/V system and break the ground path through cables between components. Start at the component last installed before the ground loop was discovered and connect the isolation transformer at different ends of the A/V cable until the ground loop is gone. They offer ground loop isolation transformers for composite video, S-video and component video applications.
C2G Stereo Audio Isolation Transformer - ground loop isolator
Ground loop isolator
2.5 cm x 10.2 cm x 3.8 cm
113 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Audio Isolation Tr...
£43.35
