C2G Cat5E RJ45 Modular Inline Coupler
£6.33
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect two Cat5E patch cables to make a longer connection
  • Stock Status: In Stock
Product codes
If you are trying to link several line cords together, or extending existing modular cable runs, C2G's in-line CAT5e coupler can help you make the right connection. The in-line coupler provides a female-to-female feed-through connection for easy cable hook-up. Capable of handling LAN speeds of up to 100Mbps, meets TIA/EIA 568A and power sum certified, the CAT5e coupler will meet all of your performance requirements.
Product Description C2G In-line Modular Coupler - phone coupler - black
Type Phone coupler - CAT 5e
Wiring Scheme T568A
Connector RJ-45 - female
Connector (Second End) RJ-45 - female
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cat5E RJ45 Modular...
£6.33
