C2G Cisco GLC-BX-U-C2G SMF Transceiver
£149.53
Delivery:
Key features
  • SFP (mini-GBIC) Transceiver Module designed for use with Cisco network equipment
  • Functionally identical to Cisco GLC-BX-U
  • LC ports designed for use with Single-Mode Fiber
  • Includes Digital Optical Monitoring (DOM)
  • 1310nm wavelength transmit and 1490nm wavelength receive
  • Supports up to 10 kilometers of cabling
Product codes
This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number GLC-BX-U. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
Product Description C2G - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 1000Base-BX
Data Transfer Rate 1 Gbps
Optical Wave Length 1310 nm
Data Link Protocol GigE
Max Transfer Distance 10 km
OEM Manufacturer Equivalent Part Number Cisco GLC-BX-U
Dimensions (WxDxH) 1.27 cm x 5.59 cm x 0.76 cm
Weight 68 g
Designed For Cisco Catalyst 2960, 2960G, 2960S, 3560, 3560E, 3560G, 3560V2, 3560X, 3750, 3750G, 4500, 4948; Catalyst Compact 2960; Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; ME 2400, 3400; Nexus 93180, 9372; Supervisor Engine 720, II-Plus-10, II-Plus-TS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cisco GLC-BX-U-C2G...
£149.53
