C2G Cisco GLC-FE-100FX-RGD Compatible SFP mini-GBIC Transceiver
£54.36
Delivery:
Key features
  • Functionally identical to Cisco GLC-FE-100FX-RGD
  • High speed 1-Gigabit connectivity
  • Transceiver type FX allows for connections up to 2km
  • LC ports designed for use with Single-Mode fibre
  • 1310nm wavelength signalling
  • Rugged design withstands more extreme temperatures than a standard transceiver
Product codes
This Cisco GLC-FE-100FX-RGD compatible SFP transceiver provides 100Base-FX throughput up to 2km over multi-mode fibre (MMF) at a wavelength of 1310nm using a LC connector. It is also capable of withstanding rugged environments and can operate at temperatures between -40[D]C to +85[D]C. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
C2G Cisco GLC-FE-100FX-RGD Compatible 100BASE-FX MMF SFP (Mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
1.27 cm x 5.59 cm x 0.76 cm
30 g
P/N: A900-IMA8S1Z, ASR-920-12SZ-IM, ASR-920-24SZ-IM, IE-2000U-4S-G, IE-4000-16GT4G-E, IE-4000-16T4G-E, IE-4000-4GS8GP4G-E, IE-4000-4S8P4G-E, IE-4000-4TC4G-E, IE-4000-8GS4G-E, IE-4000-8GT4G-E, IE-4000-8S4G-E, IE-4000-8T4G-E, IE-4010-16S12P, IE-4010-4S24P, IE-5000-12S12P-10G, IE-5000-16S12P
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cisco GLC-FE-100FX...
£54.36
