C2G Cisco GLC-LH-SM-C2G SMF Transceiver
£41.94
Delivery:
Key features
  • SFP (mini-GBIC) Transceiver Module designed for use with HP network equipment
  • Functionally identical to GLC-LH-SM
  • LC ports designed for use with Single-Mode Fiber
  • 1310nm wavelength signaling
  • Supports up to 10 kilometers of cabling
Product codes
This HP J9054C compatible SFP transceiver provides 100Base-FX throughput up to 2km over multi-mode fibre (MMF) at a wavelength of 1310nm using a LC connector. Our transceiver is guaranteed to be 100% compatible with the equivalent HP transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of HP, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
Cisco GLC-LH-SM
1.27 cm x 5.59 cm x 0.76 cm
68 g
Cisco 3825, 3825 V3PN, 3845, 3845 V3PN, 7301; ASA 5545, 5555; Catalyst 2950, 2960, 2970, 3560, 3750, 4500, 4948; Catalyst Compact 2960; Catalyst Express 500; CSS 11503, 11506; Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; ME 2400, 3400, 4924, 6524; Supervisor Engine 720, II-Plus-TS
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cisco GLC-LH-SM-C2...
£41.94
