C2G Cisco GLC-LH-SMD Compatible SFP (mini-GBIC) Transceiver
£41.31
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Functionally identical to Cisco GLC-LH-SMD
  • LC ports designed for use with Single-Mode fibre
  • Includes Digital Optical Monitoring (DOM)
  • 1310nm wavelength signalling
  • Supports up to 10 kilometers of cabling
Product codes
This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number GLC-LH-SMD. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
C2G Cisco GLC-LH-SMD Compatible 1000Base-LX SMF SFP (mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
Cisco GLC-LH-SMD
57 g
Cisco 38XX, 39XX, 4451, 8, 892; ASR 901 10; Catalyst 29XX, 3560, 3650, 3750, 4500, 6900; Ethernet Services Plus Transport 20, 40; Industrial Ethernet 2000; Integrated Services Router 11XX; Line Card E-Series; ME 3600, 3600X 24, 3800; Nexus 30XX, 7000, 93180, 93XX; Supervisor Engine 7L, 8; UCS 62XX
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cisco GLC-LH-SMD C...
£41.31
