C2G Cisco GLC-LX-SM-RGD Compatible SFP Transceiver Module
£63.67
Delivery:
Key features
  • Functionally identical to Cisco GLC-LX-SM-RGD
  • High speed 1-Gigabit connectivity
  • Transceiver type LX allows for connections up to 10km
  • LC ports designed for use with Single-Mode fibre
  • 1310nm wavelength signalling
  • Supports Digital Optical Monitoring (DOM)
Product codes
This Cisco GLC-LX-SM-RGD compatible SFP transceiver provides 1000Base-LX throughput up to 10km over single-mode fibre (SMF) at a wavelength of 1310nm using a LC connector. It is also capable of withstanding rugged environments and can operate at temperatures between -40[D]C to +85[D]C. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
C2G Cisco GLC-LX-SM-RGD Compatible 1000Base-LX SMF SFP (mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
Cisco GLC-LX-SM-RGD
1.27 cm x 5.59 cm x 0.76 cm
70 g
P/N: 4GE-SFP-LC, 4GE-SFP-LC=, 4GE-SFP-LC-5PACK=, 4GE-SFP-LC-RF, 4GE-SFP-LC-RF=, GRWIC-D-ES-2S-8PC, GRWIC-D-ES-6S
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cisco GLC-LX-SM-RG...
£63.67
