C2G Cisco SFP-GE-T Compatible SFP RJ45 (mini-GBIC) Transceiver
£55.47
Delivery:
Key features
  • Functionally identical to Cisco SFP-GE-T
  • RJ45 port designed for use with Category Copper cabling
  • Gigabit Ethernet communication
  • Supports up to 100 meters of cabling
Product codes
This SFP (mini-GBIC) Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number SFP-GE-T. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a copper network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
C2G Cisco SFP-GE-T Compatible 1000Base-T Copper SFP (mini-GBIC) Transceiver Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
GigE
Cisco SFP-GE-T
62 g
Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; Nexus 93108TC-EX, 93180YC-FX, 9372PX-E
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cisco SFP-GE-T Com...
£55.47
