C2G Cisco WS-G5484-C2G MMF Transceiver
£44.14
Delivery:
Key features
  • GBIC Transceiver Module designed for use with Cisco network equipment
  • Functionally identical to Cisco WS-G584
  • SC ports designed for use with Multimode Fiber
  • 850nm wavelength signaling
  • Supports 550 meters of cabling
Product codes
This GBIC Transceiver Module is designed for use with Cisco network equipment and is equivalent to Cisco part number WS-G5484. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Cisco and the Cisco logo are trademarks or registered trademarks of Cisco Systems, Inc. This product is not certified or endorsed by Cisco Systems.
C2G - GBIC transceiver module - GigE
GBIC transceiver module - SC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Cisco WS-G5484
3.05 cm x 6.6 cm x 1.02 cm
27.2 g
Cisco Catalyst 2912, 2924, 2948, 2950G-12, 2950G-24, 2950G-48, 2980, 3508, 3512, 3524, 3548, 3550-12, 3550-24, 3550-48, 4418, 4500, 4912; Network Processing Engine G1, uBR7200; Node Route Processor 2SV; Supervisor Engine 1A 2GE, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Cisco WS-G5484-C2G...
£44.14
