C2G DB9F to DB25M Serial Adapter
£5.04
Delivery:
Standard: 1-3 working days
Key features
  • Converts a DB9 male port to a DB25 male port; or a DB25 female port to a DB9 female port
  • Stock Status: In Stock
Product codes
Use existing serial or modem cables and serial adapters from C2G to convert existing DB9 ports to DB25 or vice versa. Serial adapters are an inexpensive alternative to buying cables. With their molded design providing a solid connection, each adapter is shielded against outside EMI/RFI interference while giving you the flexibility to meet your connectivity needs.
Product Description C2G serial adapter
Type Serial adapter
Technology Shielded
Features Molded
Connector 9 pin D-Sub (DB-9) - female
Connector (Second End) 25 pin D-Sub (DB-25) - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G DB9F to DB25M Seri...
£5.04
