C2G DVI-D™ M/F Port Saver Adapter
£9.86
Delivery:
Key features
  • Protect your display's port with this strong port adapter
Product codes
DVI adapters from C2G deliver the high performance, high-bandwidth interface needed for a connection between PCs and flat panel displays, digital CRT displays, projectors, and HDTV. The DVD-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 and is designed for high-speed digital use. These precision-engineered adapters are fully compliant with the DVI standard defined by DDWG (Digital Display Working Group).
Product Description C2G DVI adapter
Type DVI adapter - dual link
Connector DVI-D - male
Connector (Second End) DVI-D - female
Compliant Standards RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G DVI-D™ M/F Port Sa...
£9.86
