C2G Extender for Logitech ConferenceCam CC3000e - USB Extender
£467.92
Delivery:
Key features
  • Designed for compatibility with the Logitech ConferenceCam CC3000e
Product codes
The Extender for Logitech ConferenceCam CC3000e extends the camera or speakerphone up to 100 feet away from the system hub. This solution requires two standard Cat5 or Cat6 cables for extension and installation is made easy through labeling and color coding. This extension solution passes the audio and video signals to the Logitech hub, but, when extending the camera, it also passes the control signals. These control signals allow the camera to continue to move as if it were directly connected to the hub with the cable provided by Logitech. This means that full functionality of the CC3000e will be retained at full extension distance. The flexibility provided by this kit adds value and flexibility to the Logitech ConferenceCam CC3000e, making it the perfect fit for almost any application. Note: This extender is designed to extend either the camera or the speakerphone. Two extenders are required to extend both the camera and speakerphone.
Product Description C2G Extender for Logitech ConferenceCam CC3000e - USB extender - USB 2.0
Device Type USB extender
Form Factor External
Data Link Protocol USB 2.0
Max Transfer Distance 30 m
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Extender for Logit...
£467.92
