C2G HDMI Micro Male to HDMI Female Adapter Converter Dongle
£10.17
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Adapts the audio/video output of a HDMI Micro-enabled laptop so that it may be connected to a HDMI display
  • Length: 20.3cm
  • Stock Status: In Stock
Product codes
This HDMI Micro to HDMI Adapter Converter Dongle is an ideal solution for connecting the audio/video output of a HDMI Micro-enabled Chromebook, laptop or other source device to the HDMI input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output port of a Chromebook or laptop and use a standard HDMI cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
Product Description C2G HDMI Micro to HDMI Adapter Converter Dongle - HDMI adapter - 20.3 cm
Cable HDMI adapter
Technology Double shielded
American Wire Gauge (AWG) 34
Length 20.3 cm
Colour Black
Connector HDMI - female
Connector (Second End) Micro HDMI - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G HDMI Micro Male to...
£10.17
