This HDMI Mini to VGA Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI Mini-enabled Chromebook, laptop or other source device to the VGA input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output of a Chromebook or laptop and use a standard VGA cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
Product Description | C2G HDMI Mini to VGA Adapter Converter Dongle - video converter - black | Device Type | Video converter | Max Resolution | 1920 x 1080 | Interfaces | Mini-HDMI , VGA | 1 x HDMI input - 19 pin mini HDMI Type C , 1 x VGA output - 15 pin HD D-Sub (HD-15) | Enclosure Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | ||
Device Type | Video converter | |
Max Resolution | 1920 x 1080 | |
Miscellaneous | ||
Weight | 40 g | |
Enclosure Colour | Black | |
Manufacturer Warranty | ||
Service & Support | Limited warranty - lifetime |
