C2G HDMI to DisplayPort Adapter Converter
£44.02
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Connect a device with an HDMI output to a display with a DisplayPort input
  • Stock Status: In Stock
Product codes
The HDMI to DisplayPort Adapter Converter allows you to connect an HDMI source device, such as your laptop or Blu-ray player, to a monitor or display with a DisplayPort input, delivering high quality video up to a maximum resolution of 1920x1200. This Converter is the perfect solution for connecting older HDMI-enabled devices that do not support a DisplayPort output to more modern, DisplayPort-equipped monitors and displays; a functionality that is not supported by other adapters that are designed to connect the DisplayPort output of a device to a display which accepts an HDMI input. Additionally, this converter supports HDCP.
Product Description C2G HDMI to DisplayPort Converter - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort
Dimensions (WxDxH) 8.15 cm x 4.2 cm x 2.3 cm
Enclosure Colour Black
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G HDMI to DisplayPor...
£44.02
