C2G HDMI to VGA Adapter Converter Dongle - Video converter -...
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black
£17.48
Delivery:
Key features
  • Adapts the video output of an HDMI-enabled Chromebook or laptop so that it may be connected to a VGA display
  • Connects to the video output of a small laptop without causing undue stress on the port
  • Supports up to a 1920x1080 resolution
  • Use with a VGA cable for a complete solution
Product codes
This HDMI to VGA Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI-enabled Chromebook, laptop or other source device to the VGA input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the HDMI output port of a Chromebook or laptop and use a standard VGA cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
C2G HDMI to VGA Adapter Converter Dongle - video converter - black
Video converter
Max Resolution
1920 x 1080
1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15)
Enclosure Colour
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G HDMI to VGA Adapte...
£17.48
