C2G HDMI to VGA Adapter Converter Dongle - Video converter -...
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black
£17.48
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adapts the video output of an HDMI-enabled Chromebook or laptop so that it may be connected to a VGA display
  • Connects to the video output of a small laptop without causing undue stress on the port
  • Supports up to a 1920x1080 resolution
  • Use with a VGA cable for a complete solution
  • Stock Status: In Stock
Product codes
This HDMI to VGA Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI-enabled Chromebook, laptop or other source device to the VGA input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the HDMI output port of a Chromebook or laptop and use a standard VGA cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
Product Description C2G HDMI to VGA Adapter Converter Dongle - video converter - black
Device Type Video converter
Max Resolution 1920 x 1080
Interfaces 1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15)
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G HDMI to VGA Adapte...
£17.48
