C2G HP J9150A-C2G MMF Transceiver
£167.74
Delivery:
Key features
  • SFP+ Transceiver Module designed for use with HP network equipment
  • Functionally identical to HP J9150A
  • LC ports designed for use with Multimode Fiber
  • Includes Digital Optical Monitoring (DOM)
  • 850nm wavelength signaling
  • Supports up to 300 meters of cabling
Product codes
This SFP+ Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number J9150A. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
Product Description C2G - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 10GBase-SR
Data Transfer Rate 10 Gbps
Optical Wave Length 850 nm
Data Link Protocol 10 GigE
Max Transfer Distance 300 m
OEM Manufacturer Equivalent Part Number HP J9150A
Dimensions (WxDxH) 1.27 cm x 5.59 cm x 0.76 cm
Weight 68 g
Designed For HPE 6120XG, 6600-24G-4XG, 6600-48G-4XG; Modular Smart Array P2000 G3; ProLiant DL360p Gen8; HPE Aruba 2930F 24G, 2930F 48G, 5406
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G HP J9150A-C2G MMF...
£167.74
