C2G HP J9151A-C2G SMF Transceiver
£391.77
Delivery:
Key features
  • SFP+ Transceiver Module designed for use with HP network equipment
  • Functionally identical to HP J9151A
  • LC ports designed for use with Single-Mode Fiber
  • Includes Digital Optical Monitoring (DOM)
  • 1310nm wavelength signaling
  • Supports up to 10 kilometers of cabling
Product codes
This SFP+ Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number J9151A. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a 10 Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
Product Description C2G - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 10GBase-LR
Data Transfer Rate 10 Gbps
Optical Wave Length 1310 nm
Data Link Protocol 10 GigE
Max Transfer Distance 10 km
OEM Manufacturer Equivalent Part Number HP J9151A
Dimensions (WxDxH) 1.27 cm x 5.59 cm x 0.76 cm
Weight 68 g
Designed For HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
C2G HP J9151A-C2G SMF...
£391.77
