C2G HP JD119B-C2G SMF Transceiver
£41.31
Delivery:
Key features
  • SFP (mini-GBIC) Transceiver Module designed for use with HP network equipment
  • Functionally identical to HP JD119B
  • LC ports designed for use with Single-Mode Fiber
  • Includes Digital Optical Monitoring (DOM)
  • 1310nm wavelength signaling
  • Supports up to 10 kilometers of cabling
Product codes
This SFP (mini-GBIC) Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number JD119B. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
HP JD119B
1.27 cm x 5.59 cm x 0.76 cm
68 g
HP 3100-8-PoE v2; HPE 10512, 12504, 1910-8G, 1910-8G-PoE+, 3100-24 V2, 3100-24-PoE v2, 3100-8 v2, 3600-24 v2, 3600-24-PoE+ v2, 3600-24-SFP v2, 3600-48-PoE+ v2, 5120-48G-PoE+, 5500-24G-PoE+-4SFP, 5500-24G-SFP, 5500-48G-4SFP, 5920AF-24XG, 7506; FlexFabric 1.92, 11908-V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G HP JD119B-C2G SMF...
£41.31
