C2G Juniper EX-SFP-1GE-LX-C2G SMF Transceiver
£40.95
Delivery:
Key features
  • SFP (mini-GBIC) Transceiver Module designed for use with Juniper Networks network equipment
  • Functionally identical to Juniper Networks Ex-SFP-1GE-LX
  • LC ports designed for use with Single Mode Fiber
  • 850nm wavelength signaling
  • Supports up to 550 meters of cabling
Product codes
This SFP (mini-GBIC) Transceiver Module is designed for use with Juniper Networks network equipment and is equivalent to Juniper Networks part number EX-SFP-1GE-LX. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Juniper Networks and the Juniper Networks logo are trademarks or registered trademarks of Juniper Networks, Inc. This product is not certified or endorsed by Juniper Networks.
Product Description C2G - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 1000Base-LX
Data Transfer Rate 1 Gbps
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
OEM Manufacturer Equivalent Part Number Juniper EX-SFP-1GE-LX
Dimensions (WxDxH) 1.27 cm x 5.59 cm x 0.76 cm
Weight 68 g
Designed For Juniper EX 3200; 4200
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Juniper EX-SFP-1GE...
£40.95
