C2G Micro HDMI to VGA Dongle w/Power + 3.5mm
£39.15
Delivery:
Standard: 1-3 working days
Key features
  • Adapts the audio/video output of a HDMI Micro-enabled laptop so that it may be connected to a VGA display and a set of speakers
  • Connects to the audio/video output of a small laptop without causing undue stress on the port
  • Supports up to a 1920x1080 resolution
  • Use with a VGA and Stereo Audio cable for a complete solution
Product codes
This HDMI Micro to VGA and Stereo Audio Adapter Converter Dongle is an ideal solution for connecting the audio/video output of a HDMI Micro-enabled Chromebook, laptop or other source device to a VGA display and set of speakers for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output of a Chromebook or laptop and use a standard VGA and stereo audio cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
C2G HDMI Micro to VGA and Stereo Audio Adapter Converter Dongle - video converter - black
Video converter
Max Resolution
1920 x 1080
Micro-HDMI , VGA
1 x HDMI input - 19 pin micro HDMI Type D , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm
Enclosure Colour
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Micro HDMI to VGA...
£39.15
