C2G Mini HDMI to DVI Adapter Dongle
£7.26
Delivery:
Key features
  • Adapts the video output of a HDMI Mini-enabled laptop so that it may be connected to a DVI-D display
  • Connects to the video output of a small laptop without causing undue stress on the port
  • Supports up to a 1920x1200 resolution
  • Use with a DVI-D cable for a complete solution
Product codes
This HDMI Mini to Single Link DVI-D Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI Mini-enabled Chromebook, laptop or other source device to the DVI-D input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1200. Simply connect the adapter directly to the output port of a Chromebook or laptop and use a standard DVI-D cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
C2G HDMI Mini to Single Link DVI-D Adapter Converter Dongle - video adapter - HDMI / DVI - 20.3 cm
Cable
Video adapter - HDMI / DVI
Double shielded
American Wire Gauge (AWG)
32
TMDS Links
Single link
Length
20.3 cm
Connector
DVI-D - female
Connector (Second End)
Mini HDMI - male
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Mini HDMI to DVI A...
£7.26
