C2G NETGEAR AGM731F-C2G MMF Transceiver
Key features
  • SFP (mini-GBIC) Transceiver Module designed for use with Netgear network equipment
  • Functionally identical to Netgear AGM731F
  • LC ports designed for use with Multimode Fiber
  • 850nm wavelength signaling
  • Supports up to 500 meters of cabling
Product codes
This SFP (mini-GBIC) Transceiver Module is designed for use with Netgear network equipment and is equivalent to Netgear part number AGM731F. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. Netgear and the Netgear logo are trademarks or registered trademarks of Netgear. This product is not certified or endorsed by Netgear.
C2G - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
Netgear AGM731F
1.27 cm x 5.59 cm x 0.76 cm
68 g
NETGEAR ProSAFE M4300-28G-PoE+
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G NETGEAR AGM731F-C2...
