C2G QSFP-40G-SR4 QSFP+ Transceiver
£617.77
Delivery:
Key features
  • SFP+ Transceiver Module designed for use with Cisco network equipment
  • Functionally identical to Cisco QSFP-40G-SR4
  • High speed 40-Gigabit connectivity
  • Transceiver type SR allows for connections up to 150m
  • MTP/MPO port designed for use with Multimode fiber
Product codes
This Cisco QSFP-40G-SR4 compatible QSFP+ transceiver provides 40GBase-SR throughput up to 150m over multi-mode Fibre (MMF) at a wavelength of 850nm using a MPO connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
Product Description C2G - QSFP+ transceiver module - 40 Gigabit LAN
Device Type QSFP+ transceiver module - MTP/MPO multi-mode
Form Factor Plug-in module
Cabling Type 40GBASE-SR
Data Transfer Rate 40 Gbps
Optical Wave Length 850 nm
Data Link Protocol 40 Gigabit LAN
Max Transfer Distance 150 m
OEM Manufacturer Equivalent Part Number Cisco QSFP-40G-SR4
Dimensions (WxDxH) 1.88 cm x 7.11 cm x 1.35 cm
Weight 109 g
Designed For Cisco ASR 9000 Series 1-port 40-Gigabit Ethernet Modular Port Adapter, 2-port 40-Gigabit Ethernet Modular Port Adapter; Nexus 2248PQ 10GE Fabric Extender, 3016Q, 3064-E, 3064PQ, 3064PQ Front-to-Back Airflow LAN Enterprise License Bundle, 3064-X, 6001, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX-E
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G QSFP-40G-SR4 QSFP+...
£617.77
