C2G RapidRun[R] Multi-Format Runner Cable 7.6m
£51.57
Delivery:
Key features
  • CMG-rated for in-wall installations
  • Delivers crisp video and high-fidelity audio from source device to display
  • Integrates technology in the room with a single cabling system - laptops, projectors, DVD players, interactive whiteboards and more
  • Optimized for high-density signal applications - including VGA, 3.5 mm, composite video, stereo audio RCA, plus future upgrades for HDMI
  • Pull easily through walls and existing conduit - even 90° field bends
  • Future capability to support either analog or digital signals over the Multi-Format Runner cable
Product codes
RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated Break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
RapidRun Multi-Format represents the most significant upgrade to the RapidRun cabling solution to date. With enhanced engineering that includes individually shielded pairs and an isolated ground for audio lines, this runner cable meets the rigorous demand for applications in which multiple audio/video devices are run over a single cable.
Use this CMG-rated Multi-Format runner for in-wall installations that support high-density, multi-format applications. Whether hanging a projector in a modern 21st century classroom or installing a commercial digital signage system, a clean, crisp signal will be delivered every time.
Product Description C2G RapidRun Multi-Format Runner Cable - CMG-rated - video / audio cable - 7.6 m
Cable Video / audio cable
Length 7.6 m
Colour Black
Connector MUVI connector - female
Connector (Second End) MUVI connector - female
Features Colour-coded connectors, in wall mounting
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G RapidRun[R] Multi-...
£51.57
