C2G TruLink® DVI-D™ Splitter with HDCP™
Key features
  • Split 1 DVI-D output for display on 2 DVI-D compatible monitors
Product codes
The TruLink DVI-D splitter connects two HDTV displays or two computer monitors equipped with DVI inputs. HDCP compatibility means this splitter will work with high definition video for HDTV applications and high resolution PC applications. Compatible with DVI-D equipped PC video cards operating at a maximum resolution of 1920 x 1080 pixels, or with video devices at 480p, 480i, 720p, 1080i, and 1080p scan rates. Built-in DVI repeater allows lossless runs up to 10 meters from the splitter.
Product Description C2G TruLink DVI-D Splitter with HDCP - video splitter - 2 ports
Device Type Video splitter - 2 ports
Subtype DVI
Ports 2 x DVI
Features HDCP compliant
Weight 0.88 kg
Colour Black
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G TruLink® DVI-D™ Sp...
