C2G Trulink® USB to Gigabit Ethernet Adapter
£28.18
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Convert a USB 2.0 port to a Gigabit Ethernet Connection
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Form Factor: External
  • Compatibility: PC
  • Type: Network adapter
Product codes
The TruLink Gigabit USB 2.0 Ethernet Adapter is a cost-effective solution for converting an existing USB port to a 10/100/1000 Base-T Ethernet port without replacing or adding a new network card. With this adapter users can create a new network connection that allows them to connect to another network or computer without the need for a router or switch. The Auto Sensing feature detects the correct connection speed whether 10, 100 or 1000 Base-T. With speeds up to 480Mbps, file transfer between computers is fast and easy, even with large amounts of multimedia data. The adapter works on older model computers that have no Ethernet port installed, so upgrades are quick and convenient. Simply plug in the adapter and load the included software driver to get 1000 Base-T connection speeds. This flexible solution requires no external power supply.
Product Description C2G USB to Gigabit Ethernet Adapter - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports Gigabit Ethernet
Weight 91 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
Colour Black
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Trulink® USB to Gi...
£28.18
