C2G USB 2.0 USB C to USB Micro B Adapter M/F - Black
£9.85
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Adapt a USB 2.0 USB-A to USB-Micro B cable to connect the USB Type-C port
  • Adapt a USB 2.0 USB-A to USB-Micro B cable to connect the USB-C port of a smartphone, tablet or other mobile device to a USB-A port
  • Backwards compatible with USB 3.0 devices
  • Stock Status: In Stock
Product codes
This USB 2.0 USB-C to USB-Micro B adapter is the perfect solution for adapting an existing USB 2.0 USB-A to USB-Micro B cable for connecting the USB Type-C port of a Chromebook, laptop, smartphone or tablet to a USB-A port on a computer or other device for USB 2.0 communication, including high-speed data transfer and fast charging. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. Note: This cable is designed to supports USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 communication and features.
Product Description C2G USB 2.0 USB C to USB Micro B Adapter M/F - USB Type C to USB Micro B Black - USB-C adapter
Type USB-C adapter
Features Sync and charge, colour-coded connectors, nickel plated shell
Connector 5 pin Micro-USB Type B - female
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB 2.0 USB C to U...
£9.85
