C2G USB 3.0 (USB 3.1 Gen 1) USB-C to USB-A Adapter M/F - Black
£9.87
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adapt a USB-A device to a USB Type-C port on a laptop, desktop computer, tablet, or other device
  • Adapt a USB-A device, like a flash drive, keyboard, mouse, or other device to a USB Type-C port
  • Backwards compatible with USB 3.0 devices
Product codes
This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-A adapter is the perfect solution for connecting a flash drive, keyboard, mouse, or other device that has a USB A connector to a laptop or desktop computer that has a USB Type-C port for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. The USB Type-C connector is smaller than traditional USB connector and features a symmetrical design which allows it to be easily connected on the first try. Additionally, the durability of the USB Type-C connector allows for up to 10,000 connection cycles. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
C2G USB 3.1 Gen 1 USB C to USB A Adapter M/F - USB Type C to USB A Black - USB-C adapter
USB-C adapter
Sync and charge, colour-coded connectors, nickel plated shell
Connector
9 pin USB Type A - female
Connector (Second End)
24 pin USB-C - male
USB 3.0/ USB 3.1
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB 3.0 (USB 3.1 G...
£9.87
