C2G USB 3.0 to Gigabit Ethernet Network Adapter
£27.69
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect to the Internet using a high bandwidth USB 3.0 port while supporting Gigabit Ethernet data speeds
  • Stock Status: In Stock
Product codes
The USB 3.0 to Gigabit Ethernet Network Adapter is the perfect solution for converting an existing USB 3.0 port to a Gigabit Ethernet port for connecting to a network or the Internet without replacing or adding a new network card. This adapter utilises the high bandwidth of the USB 3.0 port to support true Gigabit Ethernet speeds. This flexible solution requires no external power supply, simply connect the adapter to an available USB 3.0 port, install the included software driver and connect a Cat5 cable from the adapter to an RJ45 Network port. With speeds up to 1000Mbps, file transfer between computers is fast and easy, even with large amounts of multimedia data. The adapter works on new computers that do not provide a wired Ethernet port or legacy computers which have a damaged Ethernet port.
Product Description C2G USB 3.0 to Gigabit Ethernet Network Adapter - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type SuperSpeed USB 3.0
Ports Gigabit Ethernet x 1
Dimensions (WxDxH) 7.493 cm x 2.23 cm x 1.6 cm
Weight 84 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1000 Mbps
System Requirements Apple MacOS X 10.6 - 10.8, Microsoft Windows 7 / Windows 8
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB 3.0 to Gigabit...
£27.69
