C2G USB 3.0 to HDMI Audio/Video Adapter Converter - External
£54.28
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Add up to six additional displays for duplicate or extended desktop using USB ports
Product codes
The USB to HDMI Adapter allows you to duplicate or extend desktop to a computer utilising a USB port and supports high definition video up to a 1080p resolution. The duplicate feature allows a user to show the same images from the primary display on a secondary display, making it the perfect solution when giving a presentation to a large audience using multiple screens. The extended desktop feature allows the user to expand the desktop workspace from the primary display to both the primary and secondary display, allowing different content to be shown on the two monitors, making it an ideal solution for working in multiple applications, comparing data on two different programmes or viewing multiple documents simultaneously. The adapter is designed for compatibility with USB 3.0 ports, which provides up to ten times the bandwidth of USB 2.0, and supports full motion video. This adapter has a low power requirement which, when used with a mobile laptop, will allow the laptop battery to last longer. The software required for operation is included and is easy to install and configure. Once installed, up to six adapters may be connected to the computer allowing multi-display capability.
C2G USB 3.0 to HDMI Audio/Video Adapter Converter - external video adapter - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Max Resolution
2560 x 1600
HDMI , USB 3.0
5.52 cm x 8.43 cm x 1.78 cm
Enclosure Colour
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB 3.0 to HDMI Au...
£54.28
