C2G USB 3.0 USB-C to DB25 Parallel Adaptor Cable
£26.14
Delivery:
Key features
  • Connect a parallel, IEEE-1284, printer scanner or other parallel device to a USB-C port on a PC or tablet
  • Convert a printer or other device with parallel protocol into USB protocol
  • Plug and play no drivers required
  • Reversible, symmetrical USB-C connector
  • Gold plated USB TYPE C connector
Product codes
This adapter cable will connect an inkjet, laser or other parallel printer to a computer with an available USB-C port. Multiple adapters can be connected to multiple printers at the same time, eliminating the need for a switchbox. This adapter auto-negotiates hardware recognition for faster protocol setup, and is fully plug-and-play compatible. The USB-C connector has a robust design, allowing for the connector to be plugged in and un-plugged up to 10,000 times. The sturdy construction ensures that the product provides peace of mind and is built to stand up to the rigors of the most demanding on-the-go life. The USB-C connector has a symmetrical design which is identical on both sides, so it does not matter if you plug it in upside-down or right-side-up. It will plug in the first time, every time while preventing damage to the connector port.
C2G USB Type C to DB25 Parallel Adapter Cable Black - USB / parallel cable
Connector
24 pin USB-C - male - reversible
Connector (Second End)
25 pin D-Sub (DB-25) - female
Rated Voltage
30 V
IEEE-1284
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB 3.0 USB-C to D...
£26.14
