C2G USB 3.1 USB C to VGA Adapter - Black
£26.66
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Supports up to a 1920x1200 resolution
  • Reversible, symmetrical USB-C connector
  • Compact, lightweight design
  • Plug and Play—no driver required
Product codes
This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
C2G USB 3.1 USB Type C to VGA Adapter - USB C to VGA Black - external video adapter - black
External video adapter
Bus Type
USB 3.1
Max Resolution
1920 x 1200
VGA , USB 3.1 (USB-C)
Enclosure Colour
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB 3.1 USB C to V...
£26.66
