This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
Product Description | C2G USB 3.1 USB Type C To VGA Adapter - USB C to VGA White - external video adapter - white | Device Type | External video adapter | Bus Type | USB 3.1 | Max Resolution | 1920 x 1200 | Interfaces | VGA , USB 3.1 (USB-C) | Enclosure Colour | White | Manufacturer Warranty | 3-year warranty |
General | |
Miscellaneous | |
Compliant Standards | Plug and Play |
Weight | 32 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
