C2G USB C to DVI-D Video Converter - White
£25.83
Colours:
Delivery:
Standard: 1-3 working days
Key features
  • Connect a USB Type-C device to the DVI-D port of an monitor or projector to display video
  • Stock Status: In Stock
Product codes
The USB-C to DVI-D Video Adapter Converter is an ideal solution for connecting a device with a USB 3.1 Type-C connector to a monitor, projector, or other display with a DVI-D port. The video support is built into the USB Type-C ports to feed a video signal to an HDMI HDTV or projector. This adapter supports up to a 1080p (1920x 1080 Hz) resolution, allowing it to deliver a high quality video image to the connected display. BYO DVI-D
Be prepared for any meeting, presentation, or event with the full confidence that you have the right connections in an ultra-compact design. The USB-C to DVI-D adapter allows you to connect a USB-C equipped laptop, tablet, or computer to a projector, monitor, or HDTV with a DVI input port. The compact design of this adapter converter makes it a perfect fit for BYOD (Bring Your Own Device) applications in education or corporate environments. Plug Unplug Plug Unplug Plug.
The USB-C connector has a robust design, allowing for the connector to be plugged in and un-plugged up to 10,000 times. The sturdy construction ensures that the product provides peace of mind and is built to stand up to the rigors the most demanding on-the-go life. The USB-C connector has a symmetrical design which is identical on both sides, so it does not matter if you plug it in upside-down or right-side-up. It will plug in the first time, every time while preventing damage to the connector port. Equipment Preserver.
The dongle-style adapter converter reduces strain on the USB-C port. The cable between the USB-C connection and the adapter converter provides strain relief that protects the port from strain damage as cords are moved.
Product Description C2G USB C to DVI-D Video Converter - USB Type C to DVI Adapter - White - external video adapter - white
Device Type External video adapter
Bus Type USB 3.1
Max Resolution 1920 x 1080
Interfaces DisplayPort , USB 3.1 (USB-C)
Enclosure Colour White
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB C to DVI-D Vid...
£25.83
