C2G USB C to HDMI Adapter w/ Power Delivery - Black
£26.77
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Charge a laptop, tablet, or smartphone while displaying video through the HDMI output
  • Supports up to 3840x2160 at 30Hz resolution
  • Reversible, symmetrical USB-C connector
  • Plug and play no drivers required
  • Stock Status: In Stock
Product codes
Experience 4K ULTRA HD displays and fast charging with this USB-C to HDMI Audio/Video adapter converter with power delivery which allows you to connect a device with a USB 3.1 Type C connector, such as a Chromebook, laptop or tablet, to an HDTV, projector or other HDMI-equipped display for audio and video, whilst simultaneously charging the source device. This adapter utilises the audio/video support built into the USB Type-C port to feed an audio/video signal to an HDTV or other HDMI display to achieve high-quality, 4K (ULTRA HD) video image. With delivery of up to 60 W of charging power to the connected device, this adapter converter offers a lightweight, portable and simple way to deliver video and stay charged up - whether you are out and about presenting, hot-desking or at home streaming movies. Additionally, the USB-C connector has a symmetrical design which is identical on both sides - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables, which may support a different feature set.
Product Description C2G USB C to HDMI Audio/Video Adapter w/ Power Delivery - USB Type C to HDMI Black - external video adapter - black
Device Type External video adapter
Bus Type USB-C
Max Resolution 3840 x 2160
Interfaces HDMI (female connector) , USB-C (female connector) , USB-C (male connector)
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB C to HDMI Adap...
£26.77
