C2G USB to DVI Adapter Up To 2048 x 1152
£47.38
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Add dual monitor and extended desktop capabilities to a laptop or PC
  • Stock Status: In Stock
Product codes
The USB 2.0 to DVI Adapter provides the capability to extend your viewing options from a laptop or PC. Quickly and easily connect existing equipment to a VGA or DVI-I enabled monitor or projector using your computer's USB 2.0 port. Enjoy extended, mirrored or primary display modes and allow content to be shared across multiple displays which increases productivity while minimizing additional hardware investments. This plug-and-play solution includes an integrated driver that installs quickly and easily for immediate performance.
Once the driver is installed you can use up to six adapters connected simultaneously to a single computer to allow multi-display capability. High definition performance is achieved through resolutions up to 1920 x 1080 pixels and video streaming up to 1080p. With a compact form factor and rugged housing, this unit combines durability with functionality, ensuring optimal performance and results.
Product Description C2G USB 2.0 to DVI Adapter - external video adapter - grey
Device Type External video adapter
Bus Type USB 2.0
Max Resolution 2048 x 1152
Interfaces DVI-I (dual link) , USB 2.0
Enclosure Colour Grey
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G USB to DVI Adapter...
£47.38
