C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter
£6.00
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Convert an HDMI cable to a DVI-D connection for your audio/video system
  • Stock Status: In Stock
Product codes
The DVI-D male to HDMI female Inline Adapter provides a pure digital, high definition video connection, allowing you can connect your digital source device to a DVI-equipped display device with absolutely no reduction in picture quality. This Adapter supports up to a 1080p resolution and is compatible with satellite, DVD player, HDTV, Plasma, LCD and DLP applications. Additionally, gold-plated contacts deliver worry-free performance.
Product Description C2G Velocity Inline Adapter - video adapter - HDMI / DVI
Cable Video adapter - HDMI / DVI
Colour Black
Connector DVI-D - male
Connector (Second End) HDMI - female
Features Thumbscrews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G Velocity™ DVI-D™ M...
£6.00
